1 - 17 of 17 Posts
so i used teflon tape just the cheap stuff and it still leaks really really slow but still leaks what is everyone using?? is there better quality teflon tape?? :dunno: can liquid thread sealant be used? :dunno: if so would it work better ???all info is greatly appreciated thanks :cool:
permatex 5 dollar medium ble thread locker i use it on all fittings..air and juice let mend like 3 hours done comes off w hand tools..
I Dig Chix Wit Glasses!!!
prefer teflon, hadn't gone wrong with it yet.
Cody, the guy with the '59 el camino build on here uses red teflon tape, he said its heavy duty and it works real well. I think im gona use locktite or somethin to re-do mine. I just feel like the teflon shrinks after time and creates leaks
I was also a believer in teflon tape until recently. Been using it on cars for years with no problem. Then all of the sudden I just tested a new system I installed using teflon and I had many leaks. I switched to a loctite thread seal because that's all I could find off the shelf and it seems to work well. Though, you need to use more than one drop. Man I even had three brand new push to lock fittings leak. I was real disapointed with that.
Originally posted by shoprag@Jan 29 2010, 12:52 PM~16450604
I did find 545 at a local fitting store and they wanted $49 for the bottle!
yep good stuff. They do have smaller bottles but hard to find.
The pink gas teflon is thicker and nicer to work with.
is it just the same as the yellow gas teflon? I can't really find the pink where I am so I used the yellow teflon sometimes, pretty thick (used it on my Sanden install too).
Discussion Starter #11
yeah i didnt know until i did a google search that theres like 20 different teflon tapes, pinks ,yellows ,reds, high density but i was just using the cheap white teflon at like the hardware store now is the big question where can i get the lock-tight napa maybe?? and will it be able to come off this isnt like thread locker is it? have to break the fitting trying to get it off? i heard lock-tight is some real quality stuff :biggrin: :cool:
Loctite is the brand and they have a million different products (ok, maybe not a million.... but alot) anyway, just make sure u get the Loctite 545, thats the good stuff. It will come apart if you need it to. Its not like thread locker that i never supposed to come apart :cool:
Please dont make the mistake of using LOCTITE THREAD LOCKER AND LOCTITE THREAD SEALANT. The THREAD LOCKER you are going to have a hell of a day to remove the fittings even with tools. Just use the THREAD SEALANT it comes off easy ;)
1 - 17 of 17 Posts
