1 - 20 of 22 Posts
Originally posted by dreday@Aug 19 2005, 02:27 PM~3658286
On the '93-'96 Fleetwoods, what frames are the same if any? Caprices, Roadmasters, etc...?
there is a topic some where i was tust told the 77 to 93 frames are the same 2 door wil interchange with 4 doors also .. and i was told the caprices are differant from the caddy frames.
Only cadillac frames work with caddys, caprices are like 6 inches shorter, and I think roadmasters are 6 and a half inches shorter, my friend just put a wrapped frame off a coupe on his 94 bigbody, very little differance, just be sure to keep you old bumper mounts.
77-96 4 door frame are the same. The only differents are some bolt holes depending on years. Im not shure if 2 door and 4 door interchange though. Caprice i heard are different, i think theyre shorter but the suspensions parts are the same. Im pritty shure roadmaster frames will fit why would gm spend more money to make the frames different in theyre 90s b-body cars.
Thats what I was thinking. If anything I thought surely a Roadmaster would be the same. :dunno:
Do you know what year he used? I wanna wrap mine but I hate to have the car apart for so long. So, I was gonna get another frame, wrap it, then switch 'em out. If I were to get the wrong one..........man, that'd suck big.
Roadmaster frames are shorter, they have a 116 inch wheelbase and Caddy's are 121. So they won't work, a Roadmaster and Caprice frames are the same.
Damn, that shot that idea. So, we're back to only Cadi frames work on Cadi's. So, what years & models?
77-96 all rear wheel drive 2 or 4 door will work. :biggrin:
Originally posted by dreday@Aug 19 2005, 03:13 PM~3658591
Should I listen to someone whose name is stupidGbodies?
Seriously though, do you know this as fact or is it just something you heard?
so if i change my name to mr.knowitall.....will that make you feel more comfortable
:dunno:
True-S Mike
:dunno:
:roflmao:
d body frames 77-96 dont know about the holes and what not but thats an easy fix, older lacs have the fuel lines on the drivers side
So have the 93-96 Fleetwoods, pressure and return gas lines on the drivers side and gas vent line on the passenger side...
:dunno:
:biggrin: :roflmao: :biggrin: :roflmao:
1 - 20 of 22 Posts
