1 - 16 of 16 Posts
i keep blowin valves in my front passenger dump side does one have a clue y or any ideas on how to fix it? I dont kno what it is but all i hear is a loud hissing sound, and air is shooting out of the dump vlalve
like when?
[attachmentid=240549]is that some kind of gay joke??
you can either have torn the rubber in the diaphram or o-rings depends on the type of valve or they are dirty and no closing sealing properly
Yup, Joe's right! I had that shit happen the third day I had my Herion valves installed The right rear dump valve went out I lifted the rear right instantaneously came right back down...I thought it was gonna be all downhill from there. Nevertheless, I havent had one valve go bad ever since. :cool:
i was driven and i droped and i heard a hissing from the trunk and i went to check it out and felt the dump valve and air was just comming out. i have , VALVE-DIRECT 3/8" WITH 3/8" ORIFICE 150PSI but the PSI is only at like 80 or 100 when it happens. When i open the valve the O ring is bent alil so i think the O ring is the problem but it wont stay in place how can i fix that?
Temp fix put NPT plug in it to get your ass home! :biggrin:
buy a new one since it was bent it for sure is stretched now
is there anyway to stop that from happening cuz that was the secound one and i dont really want to two new ones or keep buyin them. or am i just screwed?
Buy a better valve?
:dunno:
"VALVE-DIRECT 3/8" WITH 3/8" ORIFICE 150PSI"
Sounds like a chassis tech direct action valves, buy a new valve of better quality or have like 20 rebuiild kits with you. Good luck...
Originally posted by Mark@Aug 10 2005, 09:28 AM~3579863
what good valves? get the names to trust, parker and smc
Well every valve has its problems. Some more than others. I have seen many 3/8 and 1/2 SMC valves come into the shop leaking... I like Ascos and GC's personally. but to each his own. We use GC on our hopper without any problems so far. But i know you persoanlly had problems with gc's and some other valves, but again to each his own.
1 - 16 of 16 Posts
