1 - 5 of 5 Posts
Hi all , dumped front end this afternoon ( after hot day assume oil expanded) & nearly blew the tank off .
Two of the rods are stripped the other two are ok as tank moved at an angle but didn't go
past the seal luckily . I lifted the car straight up and the tank retuned to the original position
Does anyone one know what thead these holes are ?
Or have any advice on fixing this?
over it
The block isn't tapped. The rod is threaded on both ends and use nuts.
A piston pump has the end cap drilled and tapped but not the block.
problly just need new rods. They are comonly a shaft with threads on each end with nuts.
oh, and drain some oil out of your tanks, they are too full :)
no problem any more , I just need new rods & less oil :wow: was just in a panic
because I didn't have time to look at it properly b4 I left for work
cheers guys
1 - 5 of 5 Posts
