1 - 9 of 9 Posts
Will a '67 Impala Body fit on a '70 Impala Frame ???
I saw you have several topics made asking this same question so I did some research for you.
Chevrolet Parts Interchange Manual
59-60 all but the vert
59-60 vert
61-64 all but the vert
61-64 vert
65 all but the vert
65 vert
66 all but the vert
66 vert
67-68 all but the vert
67-68 vert
69 all but the vert
69-70 vert
70 all but the vert
59-60 vert
61-64 vert
65 all but the vert
65 vert
66 all but the vert
66 vert
67-68 vert
69 all but the vert
69-70 vert
70 all but the vert
Sorry man, but i'm a little slow. LOL. But does that mean it'll work....Yes or No.
Thanx man For the research.
59-60 vert
61-64 vert
65 all but the vert
65 vert
66 all but the vert
66 vert
67-68 vert
69 all but the vert
69-70 vert
70 all but the vert
x2
I was supposed to get back with John, but I ended up getting busy and forgot.
This is the info I originally gave him, but I was only 99.9% sure, and not 100% sure, and its that .01% that would have someone pissed off at you because they went out and bought a frame that they cant use.
But good looking out Tom, good info.
If I remember correctly, this project is for president of the car club that John is from, he totaled his 67 Caprice, and got injured pretty badly, so the club got him another car. ;)
67-68 will be what fits it. The 70 frame will not.
I'm asuming its not a convertable frame because they have more body mounts.
But using a covert frame would be better because it is just a extra mount under the door on each side and there is already a brace there on the ht bodies. I am using it on mine. ;)
59-60 vert
61-64 vert
65 all but the vert
65 vert
66 all but the vert
66 vert
67-68 vert
69 all but the vert
69-70 vert
70 all but the vert
GOOD LOOKING OUT HOMIE!
I believe it will work, the only differance I have seen is the pitman arm goes through the frame on 65-66 and on 67-70 it bolts to the inside, simple thing to fix. The other thing is where the upper trailing arms boly on the bottom lip goes the opposite directions, I'm not sure when the did that.
1 - 9 of 9 Posts
