1 - 18 of 18 Posts
I wrapped a setof control arms and molded them with a grinder, but they rnt as perfect as i want. SO i want to put some kind of body filler on them to fill the cracks
1st what kind of body filler should i use
2nd do i need anything else with the body filler to make this control arm ready for paint.
3rd do i need some primer if so what kind?
should i wet sand or dry sand....?
I don't mean to answer a question with a question; but wouldn't that shit just crack and fall off? :(
Thats not a question with a question thats a rhetorical question. It will when exposed to heat and vibrations.
So to touch it up should i jus go over it a couple more times with the welder and a grinder or is there another way?? I jus have some pin holes i wanted to fill.
answering ur rhetorical question with a another question... how do people paint them, without it cracking and fallin off??
use high build primer /sand / paint / clear!
Im not settling for those 230 dollar ebay crappy arms, i did mine myself (my first set of arms) they look great but they have a few lil pin holes that i want to fill before i paint... how does the paint stay if the bondo is gonnna "crack".... someone give me some good input, instead of stupid comments
dont use bondo mayne........why put that shit on there, wen later down the road your putting a risk of having to re-do them..........if u want them to be the best possible...........keep welding and grinding until it is clean an smooth
my $.02
1 - 18 of 18 Posts
