1 - 20 of 23 Posts
DAVIDSIMPALAS
we use the evercoat Z-GRIP , but it leaves alot of pinholes so you have to go over with a glaze putty
evercoat extreme is great with no pinholes but its thin like putty ( also costs 55.00 a gallon )
so if you rough in the body work with z grip and then coat it with extreme you wont have any problems , but i will suggest if you use evercoat bondo use evercoat putty , dont mix the manufactors
The Great White Hype
im sorry fellas its evercoat light weight it comes with a white label any autobody supplier should have it cheap and easy to work with
1 - 20 of 23 Posts
