My car is a 1980 Cadillac Coupe. Damn, was working fine until I decided to replace a faulty door jamb switch on Friday. I then started to clean up the wires under my dash. The installer of my alarm did a crapy job of running the wires (5 years ago) so I decided to organize it. Then later went to the store and noticed that my left turn signal wasn't flashing, but other lights seem to pulse. But when turned to the right it'll flash. NOTE: brake lights were working and hazard lights) So the next day went to my local AutoZone to buy and replace the turn signal switch, checked turn signals (flashing l and r) 4 way hazards too and rear brake lights lit up when brakes applied. Then on Sunday on the way to work when changing lanes it wouldn't flash neither left or right, and if it did it'll flsh once then there was a pause and it'll flash again and sometimes flash real fast, checked hazards that too and had no brakes lights. Later rechecked and my turn signal lights were flashing real fast (like a euro does) but had no brakes or hazards. My parking lights are fine. When I got to work had some time to remove the cover from under the dash and noticed a fuse that was melted (the outer coating) but the metal strip inside was OK. The number of the fuse is 25. BTW, I heard some clicking sound coming from the steering wheel, I know there's no flasher inside of that so can it be the turn signal switch inside and the related wiring to it? Any help or suggestions is appreciated. Anybody else had the same issue if so how or what corrected the problem. I'm going to recheck again what I moved around maybe a wire is touching somewhere. Much thanks guys.
