SOME TIMES AS IM DRIVING MY FRONT BRAKES LOCK UP EVEN WHEN IM NOT ON THEM THEY GRAP SO HARD YOU CAN SMELL THE BRAKES AFTER A FEW MINUTES THEY WILL LET GO ARE I HAVE TO PARK AND COME BACK OUT AND THEY WILL BE DONE RELEASED ANY IDELS ????????
wheel cylinders?
my cutty had bad cylinders and the rear driver side tire would lock up and i changed both of them and then problem solved
look for moisure/leaks around the cylinders, hose, lines, and master cylinder
( and foompla is gonna come on here and try to make me sound stupid :uh: )
Originally posted by sleepy526@Sep 11 2005, 10:00 PM~3795703
wheel cylinders?
THANK'S YOUR RIGHT MY PREZ SAID THE SAME THING BRAKE FUILD TO DIRTY AR4E MASTER NOT HOLDING PRESSURE
TDMMC
I'm not going to try and make any look stupid ;) Front brakes on those cars have calipers not wheel cylinders,But they do stick sometimes.and the brake lines sometimes will colapse,you can try and change that line first,and bleed the shit out of the system. ;) Good luck homie
and on the rear they have cylinders
and a leaking cylinder will cause the REAR wheels to lock up
i know from expirence
and yes the calipers might be getting stuck and i forgot to mention that
TDMMC
Thats cool homie he did say front brake problem. ;)
I DIDNT SEE THAT SHIT
MY BAD
