Originally posted by trudawg@Nov 26 2003, 03:38 PM
I have a jack that will not lift up at all anymore. It all started when it would lift halfway through a single pump :confused: :dunno:
now it doesn't lift at all
Probably a bad o-ring!! Look on it for a plug that is about a half inch wide and there should be a oring and a check in there! :biggrin:
check your shaft to see if it is pissing oil all over it when you trie to activate it, if it is ,BAD O RINGS. very common and easy to fix
