You know anybody with a spark tester? Maybe its a weak spark.
Hows your cap and rotor look? If they're ok, go have the ignition modual tested at Napa or somewhere. If those all check out then its probably the pickup coil, which means pulling the whole distributor out.
This is all assuming that you ARE getting gas to the carb. :biggrin:
