im burnin oil but its only when it gets up in the rpms like 2600 + its in a chevy 350
mine used to do that, until i bolted my dipstick back to the block and replaced the valve cover gaskets.Originally posted by DekeDamage@Aug 14 2003, 07:55 PM
Mine smokes when I turn my car off??
mine did exactly that, until i replaced my valvecover gaskets, it used to smoke when i turn off the engine, it got real bad after a while, that it even smoked while i was going down the road- about a 10ft cloud of smoke, under, and all around my car.Originally posted by DekeDamage@Aug 15 2003, 02:45 PM
Well my smoke comes from the engine...you can see it, its on the passenger side exhaust manifold/header/exit pipe from the engine thingy...whatever its called...my mechanic said it could be seals, rings, valves. If it is should I just rebuild it?
