G
yeah, ive done that, only thingihad to do was readjust the aligment, no problems with wheel wobling. does it woble with the wheel off the ground?
Originally posted by swangalangs@Dec 10 2003, 12:24 AM
Has any one did this on g body with out any problems? (like the pass wheel wobling). It does have the belly split 1 inch and a full stack of springs if that makes a differance..
CHECK THE BALANCE ON YOU WHEEL MAN IT MAY BE GONE OR THE WHEEL MAY BE NOT TRUED WIRES IF THE R NOT TRUE OR BALANCE CORRECT WILL WOBBLE LIKE A MOTHER FUCKER AND AT THE ANGLE THE WHEEL IS AT WOULD MAKE IT WORSE ALSO CHECK ALL YOUR BEARINGS AND YOU HUB
Hot Head President
i also say it has to do with your rim, its prolly outta round, or loose spokes, or may need to be balanced....or it can also be your wheel bearings
