1 - 17 of 17 Posts
hydroblood
I changed the tranny, then started it up and it cut off, now it wont crank, it ran good before i put the new tranny in what could be wrong?, anybody got any idea's
on the pass side by the oil filter there are 3 wires that go to the oil pressure sinding unit check the wires make sure you did not pinch them,they might be bare most of them are. tape them up or replace,
hydroblood
thanks, everytime i try to start the car it blows the fuel pump fuse? i am lost,
Super Smasher
whoa whoa ! my caddy did the exact same thing....im talking exact same!! new tranny blown fuel pump fuse? every time.. i couldnt figure it out (either could any one else) I used it as a excuse to put the 350 sbc in it. but this very interesting :0
Brougham
do what this guy said :)
just check the wires
hydroblood
thanks fellas, i checked them and sure enough they were pinched togather and melted a lil, i fixed it and its doing pretty good now, i have to break it in tomarrow, the tranny is still hesitating to change gears so hopefully itll work out, thanks again
Originally posted by PIMPDADDYCADDY1966@Aug 25 2005, 10:07 PM~3692347
is it shifting hard like its not wanting to change gears,if so adjust the D-tent cable
ok check that the vacuum modulator if applicable is hooked up ...
hydroblood
Discussion Starter · #15 ·
ok now it is shifting hard and i have to get up to some speed to change gears, and when it does it jerks into gear, i need more info one the d-tent cable and the vacuum modulator, thanks for yall's help
it doesn't have a vacume modulator. the dtint cable is on the passenger side of the throtle body. at the top of the cable, there will be a little spot on the cable where u can push down and push the cable back in.
1 - 17 of 17 Posts
