1 - 10 of 10 Posts
i started ripping off my top today cuz its starting to crack and been dyed so many times............here is what i need to know...there is foam underneath about 1/8" thick.......do i scrape this all off or just re use it most of it is still perfectly intact......or do i just scrape it all right off and put new material right on the roof?
the sewing is not a problem just this is....any input is great
just finished tearing mine off yesterday,, the foam is closed cell foam, if its in good shape you can reuse it, problem is when removing the vinyl usually chunks of the foam will come off with it, these irregularities will show through under the new vinly,, i removed everything, and yes its a pain in the ass, and no there is no easy way,,, good luck..
the car is by no mean a show car i just need something on there to cover it...i got the old one off with only taking a couple lil chunks off......
now is it ok if the foam gets wet or will that just screw it up for me?
well what can i say you posted the right topic when it said cadillac
to answer your question no you can never reuse the foam and yes their is an easy way to remove it with a cheap 12$ grinder at the hardware store then shoot some primer the real shit not spray cans then the glue then the ribs if your going for the fake convertible look. then the vynil, and last but not least the trim if you need more help please pm m,e
neither i am just confused....just askin if i take the old foam off do i need to put fresh stuff on or can i just glue the vinyl to the roof?
yes of course my bad definetly put 1/4 thickfoam on let it set before anything if not you may get rust spots which do show through vynil now iam going to sleep i am traveling to odessa tommorow for the big show so peace out
actually i have seen the old foam reused many times, and no a grinder is not the cure for the problem,,it will tear the foam off yes,, but the glue it will only smear around and burn into the paint.
1 - 10 of 10 Posts
