Originally posted by kaptonkrewl2003@Nov 7 2003, 11:23 PM
sup peoplez i gotta 89 brogham 4 door with a 307 ci i have a very siff spring now but it seems as if it is to stiff is this possible?i have double pumped the front with reds stylin pumps 1 bay of six bats it seems like i cant get the height to climb ,if i hit the switch once it hopps up 6or8 inchs but the highest iv been is about12 or 15 inches no matter how long i keep hoppin i wanna see at least 20 plus coil rate maybe? help guys
:dunno:
Answer, yes. Have hit 39'' with my 91 so far this summer. 2 very important factors are indeed the springs (run a full stack for max inches, I use 4 1/2 tons myself) and batteries. The higher the voltage, the bigger the inches. Am running 12 batts @ 72 volts in mine w/ #11 gears to the nose.
Keep in mind, with more inches comes more stress on the car. Dont try to push it too hard unless you have some major reinforcement done to that frame, or you will be asking for trouble.
Good luck! :biggrin:
