Is it possable for a cylinder shaft to bend and would it cause them not move?? or also what would keep them from not dropping back down all the way with out a line even attached???
I had one of my front cylinders bend in half when the cup slipped off the coil spring... I had to cut the cylinder in half just to get it out... Also, you need to check to see if your cylinder isn't jammed... I knew a guy that had that happen to him every time he hopped his S10 Blazer... Just undo the hose and jump up and down on it... If it's just jammed, it should unjam and fall...
