1 - 16 of 16 Posts
Probably a dumb question but I'm moving and my 63 is laid out in the driveway w/ dead batts and no charger. Is there any other way I can lift it w/ jumper cables or something? Thanks...
Face Puncher
you might be able to lift it with jumper cables from a car thats running, it'll be real slow though, only do 1 pump at a time like that
Why would you let your batts get that dead?
Ask a friend its going to cost you more in the long run, when your batteries go bad.
Face Puncher
Originally posted by OC*SS@Aug 26 2005, 07:06 PM~3699216
How exactly would I do that?
Hard times...no $ for multiple charger  :(
take the jumper cables, clamp the ground side to your rack, and the hot side to your motor stud...
on the other end...
take the hot side and clamp it to the cars battery, and tap the ground side to a ground, the pump should spin..
dont hold it though..
tap tap tap.
it's gonna spark some when you touch the ground
this should get you lifted enough to drive it, a running car produces about 14.2 volts
damn those batterys are dead.
on the other end...
tap tap tap.
Thanks a lot for the tip man...
I hope not for good!
on the other end...
tap tap tap.
this should get you lifted enough to drive it, a runn ing car produces about 14.2 volt i wouldnt recommend this with a neew car thought some new car computers are very sensitive and you could fry it,
dont lift on dead batteries jump it like they have said you run the risk of stickin noids and burnin batteries..
Originally posted by CrystalCutlass@Aug 26 2005, 09:57 PM~3700574
Hook up a treadmill to your batteries, and get your ass running...
damn :0
1 - 16 of 16 Posts
