1 - 2 of 2 Posts
ok....3 days ago i was trying to change my fuel filter on my 81 cutlass....it has the stock 3.8...so when i tried 2 out the bolt that holds the fuel filter back in it striped the hell put of the carburator...so i decided 2 change the carburator from my junked regal....and now my car keeps telling me my battery is low and last night my brand new optimal baterry died ...so im riding on this cheap battery right now....and when i am at stop light my car shakes alot and turns off on me....can any1 help me out n tell me wut 2do please...thank every1 that helps
Ok....First of all, when you swapped out the card, was the alternator wiring messed with at all ?? Are you getting 14.5 volts at the battery when at idle ?? Turn up the idle so it stays running, then you can adjust your mixtures. You might be able to get that junkyard carb to work for you. Also check ALL your vacuum lines. Make sure your "ported" and "manifold" vacuums are correctly routed. Let me know
John's Customs
1 - 2 of 2 Posts
