1 - 12 of 12 Posts
Well here I am again with yet another questin onthe project 84 Monte.
I cant seemt o get gas in the damn thing. Every time I try ...the pump nozzle clicks and it acts as if it is full.
I was going to replace the tank but was told that is a common problem with mid 80's g-bodies. any ideas or suggestions would help greatly.....
thanks again to all who take the time to answer.......................RO
[snapback]3482224[/snapback]​
get under it and remove the fill tube ...check both sides
my 64 does the same thing .. looks like theres a crooked tube in mine .. and well i am lazy like that
the reason the nozzle clicks off is because the vapor recovery tube (part of the gas pump nozzle) is getting liquid gas in it. basicly the little holes on the side of the end of the nozzle. you need to pump slower or pull the nozzle out a little bit and hold the boot back with your hand so it will turn on.
sounds to me like the anti sifen(ya, i know i spelled the wrong) valve in the filler neck is not letting the gas through as fast as it should. it is the little screen type thing that keeps people from shoveing a hose down your tank to steel your gas. its should be in the filler neck where the neck meets the tank, not the one you can see with the gas cap off.
SPELL CHECK
[snapback]3494398[/snapback]​
You hit it on the head, man. Exactly what I was going to say. Ah, brings back memories of pumping gas while I was in college, and you'd get these cars that had to be babied by hand. What a PITA! :cheesy:
[snapback]3495136[/snapback]​
lol, california "stage II vapor recovery" ceritefied!!!!!! the c.a.r.b. and e.p.a. love me, well execpt i drive a car that gets 9mpg and leaks oil everywhere :biggrin:
1 - 12 of 12 Posts
