1 - 20 of 24 Posts
looking for the specific years of caprice spindles to work on my 87 monte, i have some out of a 91 caprice available for next to nothing, will they work or no??? thanks. :cool:
yes they will....
just remove the ABS sensors from the spindles and you're good to go...
Originally posted by grandson@Sep 26 2007, 08:21 PM~8876393
what is the advantage of caprice spindles?
are they drop spindles or just stronger or ... ?
room for more coil and higher lockup for hopping
Originally posted by blueouija@Sep 26 2007, 05:08 PM~8876323
yes they will....
thank you very much man, i got the spindles, calipers and rotors for $70 for both sides, building a street hopper ;)
i got em on my regal. For the g-body all u have to do is throw caddy uppers which are 1 inch longer than stock g-body arms n caprice spindles n ur good to go! :cool:
i'm gonna extend and reinforce my stock uppers, which makes me think, will the spindles effect my wheel angle????? i was planning on extending my arms 1"
the spindles will not affect wheel angle...all they are is a lil bit longer than a g body spindle so you can pack more coil into the car... but make sure you have spindles with the smaller rotor size or you will have to grind the calipers to make 13's fit if thats the way you are goin....
rider since birth!!!
BIGGER BRAKES TOO!!! WORKS GREAT 4 ME :cool:
the caprices had 2 different sizes... the police package and station wagons had a larger rotor.. 12" i believe where as most coupes and sedans has the 11" rotor
GOFUCKURSELF
Originally posted by 6Deuced@Sep 26 2007, 09:13 PM~8878042
i was told the caprice spindles fit 13's the caddy spindles dont.
it will fit but u have to grind the caliper..........
you brought up a good point
caprice came with two different sized brakes....
the 11 inch rotor
and the 12 inch rotor...
the spindles that use 11 inch rotors will fit 13's
1 - 20 of 24 Posts
