1 - 16 of 16 Posts
when i raise the car up all the way it dog tracks if it is lowered its fine. I think the piviot arm behind the rear end is causing this could i take the arm off and be ok? If not what can i do to prevent this problem?
SINGLE PUMP NO WEIGHT
No!
It's been working fine.......leave is as-is unless you want a higher lockup
Originally posted by big pimpin@Aug 18 2005, 10:46 AM~3649901
No!
Why not? :dunno:
Look at the banana bar in that pic it is moved over about 3" from center already. Imagine how much sway it would have with out the panhard bar. :0
Originally posted by timdog57@Aug 18 2005, 09:49 AM~3649911
Why not?  :dunno:
it would be awesome!!!!!! :cheesy:
awesomely dangerous. :biggrin: If he takes it off I want him to keep a camera with him at all times so when his rearend slides out from underneath the car while driving he can take a pic. :biggrin:
hit a corner and one side would look like it was 1993 with some 15x10s on a mini truck! :cheesy:
:roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :roflmao:
G
the reson your car dose that is because it was never designed to go up that high the only way to fx it is to put 2 uper trailing arms on it like a cutlass or regal the 1961-1964 impalas only had one uper trailing arm with a bar from the frame to the axle to keep it from moving side to side
1 - 16 of 16 Posts
