1 - 10 of 10 Posts
my monte carlo heats up really fast. even if i have it running for only a few mins it gets pretty hot. tha coolant waz changed about a month ago and i put a bigger radiator in it. any1 kno wut could b tha problem? or do i just need som elctric fans to keep it kool?
Is the coolant properly mixed?
Is the thermostat stuck?
Is the thermostat in backwards?
You mentioned adding electric fans.... did you remove your mecahnical fan or the fan shroud?
id say your thermostat would be the problem, you should replece your whole setup just so you have your car hella reliable and sanitary, all the hoses thermostat and housing and mabey even a new waterpump and you engine will be happy
1 - 10 of 10 Posts
