1 - 13 of 13 Posts
Originally posted by 84 2 dr cut@Oct 19 2006, 02:15 PM~6401885
sounds like a starter prob also make sure  batt cables are on tight
Thanks man, its my sisters car and im about to head out there now..I figured it was the starter but I'll make sure to check those batt cables because she told me this happend twice already and each time this guy seemed to fix it by moving around the batt cables
The clicking is the starter solenoid opening and closing because there isnt enough juice to hold it closed when youre trying to start the car.... its a dead battery or a bad connection.... check the terminals like you said, clean off any corrosion, tighten them properly and glue or tape a penny to the top of the battery.
never heard that one, whats the penny for???
[/b]
<!--QuoteBegin-corndawg
@Oct 19 2006, 06:59 PM~6403957
To avoid acid residue build-up on battery terminal posts and cable clamps, place a copper penny on top of the battery between the battery posts. (The copper penny will usually stay in place without falling off.) The copper in the penny will absorb the acid residue from the posts and keep the terminal posts and cable clamps clean. On older batteries that appear to give off more acid residue, add an additional penny and place each penny one to two inches from the posts. Make sure that there are no exposed areas of the battery cables near the post terminal clamps, since the stranded copper cables will also absorb acid residue. In about 6 to 9 months, the penny will turn into a small lump of greenish powder. Merely wipe off the powder with a paper towel and replenish with another copper penny as required.
Thanks homie...
I've written this down for future reference...
destroying government property :0
1 - 13 of 13 Posts
