CAR WONT STAY UP AFTER HITTING SWITCH!
377 Views 4 Replies 3 Participants Last post by  nyd40cal
TRIED CHANGING DUMPS....BOUT 5 OF THEM...WHAT R THE ODDS OF ALL OF THEM BEING BAD...OR AM I OVERLOOKING SOMETHING...IT WILL STAY UP WHEN I DO IT MANUALLY WITH THE SLOW DOWN
1 - 5 of 5 Posts
your check valve is leaking.
you check leaks in a series.. dump, and its seals..then check valve, Thats if you dont have any visable oil leaking out.
did you just build the pump?? maybe you installed the check valve backwards.
nah...i didnt build...i will try the check valve....do i just turn it around?
close the slow down......if drops its the check, assuming the oil isn't leaking out.
if it stays up.....its the dump.
1 - 5 of 5 Posts
