1 - 20 of 28 Posts
IM PUTTING IN 14S IN THE BACK OF MY 77 CADDY.
IS THERE ANYTHING I SHOULD NOW BEFORE INSTALING?
LIKE WHAT KIND OF MODS. AM I GOING TO HAVE TO DO?
NEED INFO PLEASE
i would say your wasting atleast 2-3 inches of cyls,caddys only use about 11 inches from ground to highest point of lift.they also will stick through the back deck, that sucks i got 12's in my caddy
what ever, you don't need a chain bridge for standing 3's.... do what you want home, its yo shit.....14's will work fine just do a little cutting so your uppers get a little more travel....
SO I DONT NEED A BRIDGE.
JUST CUT BELOW MY TOP TRAILING ARMS AND IT SHOULD GET SOME
DISTANCE
IS THAT WHAT YOU ARE SAYING HOMIE
IT LOOKS LIKE TO ME THE TOP TRAILING ARMS
ACT ALMOST AS A CHAIN BRIDGE ANYWAYS
WHAT DO YOU THINK?
and ill say it again kaptonkrewl2003 Posted on Dec 15 2003, 09:34 AM
i would say your wasting atleast 2-3 inches of cyls,caddys only use about 11 inches from ground to highest point of lift.they also will stick through the back deck, that sucks i got 12's in my caddy and a bridge is for standing threes!!!! duh!! :angry:
Originally posted by gold cutt 84@Dec 16 2003, 10:37 AM
yes 14's stick threw the deck matters how much spring you gotand if its coil over. :cool: :uh:
I HAVE COIL OVER INBACK THE CYLINDERS ONLY STICK OUT ABOUT 6 INCHES.
Originally posted by 77CADDY+Dec 15 2003, 05:07 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (77CADDY @ Dec 15 2003, 05:07 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--Dressed2Impress@Dec 15 2003, 12:16 PM
WHAT DO YOU THINK?[/b][/quote]
NO WAY
Note the streching of the metal and i did not pull that bushing up it fell out when i pulled the arm off....you sould extend you arms a inch, buy the prohopper trailing arms, or put a bridge in and chan it off at 12 inches if you are interested in buying the prohopper arms pm me i know a guy that can give you a good deal
Originally posted by droppen98+Dec 16 2003, 12:52 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (droppen98 @ Dec 16 2003, 12:52 PM)</td></tr><tr><td id='QUOTE'>
WHAT DO YOU THINK?
NO WAY
Note the streching of the metal and i did not pull that bushing up it fell out when i pulled the arm off....you sould extend you arms a inch, buy the prohopper trailing arms, or put a bridge in and chan it off at 12 inches if you are interested in buying the prohopper arms pm me i know a guy that can give you a good deal[/b][/quote]
I THINK IM JUST GOING TO LIFT IT UP AND CHAIN IT RIGHT THERE
WHAT KIND OF CAR DID THOSE ARMS COME OFF OF , MY ARMS LOOK LONGER.
Discussion Starter · #13 ·
WHAT DO YOU THINK?
NO WAY
I CHECKED THOSE ADJUSTIBLE ARMS OUT THEY AINT BAD FOR 150.00
i got 16s in my 83 cadi the it only stickes out like 2 inches. . and i could stand three. no chain bridge no nothin'. . . altho 12 bateries might help me a little :biggrin: just i little reinforcin for the uppers
Discussion Starter · #15 ·
DO YOU HAVE ANY PICS.? I ONLY HAVE 8 BATT. AND 4R PUMPS I GUESS ILL HAVE TO SEE WHAT IT DOES FRIDAY WHEN I GET MY NEW PUMPHEAD SEALS IN.
Discussion Starter · #19 ·
Originally posted by capriceman75@Dec 17 2003, 11:27 PM
i know for a fact you lock up a bit higher with the coil over an chain bridge set-up
HOW MUCH HIGHER WILL IT LOCK UP DOG?
JUST ESTAMATE IT.
Discussion Starter · #20 ·
Originally posted by 77CADDY+Dec 18 2003, 05:59 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (77CADDY @ Dec 18 2003, 05:59 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--capriceman75@Dec 17 2003, 11:27 PM
JUST ESTAMATE IT.[/b][/quote]
WASS UPPP? HOMIES
1 - 20 of 28 Posts
