SO BASICLY WHAT YOU ARE SAYING IS IF YOU DONT HAVE ENOUGH WIEGHT IN YOUR TRUNK TO PUSH ONE SIDE OF THE CAR DOWN ALL THE WAY THEN YOU NEED A BRIDGE.Originally posted by enough_talkin@Dec 18 2003, 03:16 AM
im no expert but basically it hooks to the middle of the car stopping upward movement lower than the cylinders can push it...you dump one side and pump the other....when the chain stops and the cylinders keep extending it pivots and pushes the extending side of the car up...
http://www.layitlow.com/tech/suspension_ch...ainbridge.shtml
SO BASICLY WHAT YOU ARE SAYING IS IF YOU DONT HAVE ENOUGH WIEGHT IN YOUR TRUNK TO PUSH ONE SIDE OF THE CAR DOWN ALL THE WAY THEN YOU NEED A BRIDGE.[/b][/quote]Originally posted by 77CADDY+Dec 18 2003, 08:18 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (77CADDY @ Dec 18 2003, 08:18 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--enough_talkin@Dec 18 2003, 03:16 AM
check this: I gotta 84 Cutty 2 pumps 8 batts if I install a chain bridge I can stand a 3? with no 3rd pump?Originally posted by enough_talkin@Dec 20 2003, 12:38 AM
you dont need a chain bridge to pull a standing 3 in all cars..it will help in any car..with the car pivoting it forces that side up alot higher in turn giver you a much higher 3 wheel..if you like 3 wheeling i suggest installing one![]()
12S IN THE BACK TO MAKE SURE,HA HA :biggrin:Originally posted by 1LOWCHERO@Dec 21 2003, 11:27 PM
10 inchers in the ass with 8 batts 2 pumps is cake. full tank of gas too, haha.
14's in the back 8 batts 3 pumps bridged and riding on fumes... :biggrin:Originally posted by 1LOWCHERO@Dec 22 2003, 12:27 AM
yoy will need a third pump to make a chainbridge work...Originally posted by viznic@Dec 22 2003, 03:04 PM
Yeah, I got 12s in the back, I may as well git some 14s and a 3rd pump. Yeah, the mofo does a rolling 3 easy, but I wanna sit the sum bitch! Thanks!
