i'm chargin my front batts which go to a single pump n was wonderin, if i ran the 3 chargers i had at the same time (ones 20 amp, ones 25, n ones 35) would it make the batteries be all at different charges n therefore mess with my performance, or seeings they're all goin to the same pump will it be coo? lemme know asap cuz they on now. thanks
G
well considering that they each have different charging outputs, they will not charge equally, also i wouldnt recommend using that type of charger, you SHOULD use like a 3amp charge, its slower but batts, will perform better,last longer.
Never charge at more than 10 amps. Your batts will not last very long that way.
Lower the amps deeper the charge
Deeper the charge longer it lasts.
sears 5amp charger. its automatic, so it wont over fry your cells. it will go from 5 to 1 amp, then the batter is good as new. :0 :biggrin: :cool: :cool: :cool:
