mid 70s to mid 80s were the gas saver days and so they put smaller carbs on the big motors to use less gas. Edelbrock recommends a 650cfm carb I believe for that size motor and I doubt your 2 barrel moves that much air. A 4 barrel will also use more gas, I dont see how it would use less? Its the same as a 2 barrel, 2 barrels are used all the time but when you open the throttle all the way the other 2 open. So you would feel the most difference when you floor it.
Its a pretty easy swap. New intake, carb and maybe throttle linkages. If you want to go cheap there are tons of used aluminum intakes on craigslist and ebay and some carbs but I would rebuild them if they are used.
