1 - 10 of 10 Posts
Hey guys! Heres what im looking to do, its a 1985 Chevy S-10 Rear wheel drive, and I want to install a nice clean 2 pump 4 battery setup with Accums. Now My problem isnt setting up the pumps batts or any of that, my prob right now is in which direction I would like to take doing the rear suspension, now there where two things I was thinking, Coil Over with a bridge or the old traditional way which is working off of the LeafSpring. Now im kinda confused on what better to do for my situation I didint really want to cut the bed of my truck out I just want to go up and down simple. I did see a diagram from Prohopper on how to do this and was wondering if anyone had a link to it. I looked on Prohoppers site and they no longer have that info. Now I would like someones suggestion on how to do this and whats the best way. Also would I have to take out some leafs on the truck if I wanted a lower stance in the rear with a coil over? If someone would help id appreciate it.
I found this setup right here and need to know whats the best way to get a nice lowered stance all I have in the rear are Lowering Blocks that sit pretty low but when I put the cylinders in the rear will it change anything like change the stance?
I know about the s-10 chassy , because of owning one and working on them . And i know that the chassy's are real weak. I recomend at least boxing the c section part of the frame . That prohopper diagram would work good for you to get started.. a 4 link would be much better than leaf apring though. Cause i started mine like that.. I did a coil over- bridge though, with the mono leaf . But i also cut the center section of the bed out. I welded the c channel to the c notch i put in the frame. Im sure that leaf spring setup would be what your lookin for.
Thanks! Now the lower brackets they just get bolted to the leaf? And the cylinder gets bolted to that bracket?
nah i think the plate bolts to the leaf. the cylinder screws to that, then there is a c bracket the cylinder passes through Welded on to the frame.
I highly recommend you reinforce the rear frame, as someone already mentioned that the s10 C-frame is very weak. My truck had a c-notch, and with the flexing of 3 wheeling, I cracked the frame on both sides right by the c-notch. :(
Since, I've had the frame boxed in from the back of the cab, all the way back.
The cylinders on my ride are also mounted on the side of the frame, as I did not want to cut the inside of the bed either.
Thanks for the help! I really needed to know how things went before I started on this thing, I really dont want to cut my bed so ill do it with the cylinders mounted on the side.
No problem.... I'll see if I have some pics.. to post on here!
1 - 10 of 10 Posts
