1 - 2 of 2 Posts
I got the trim tool with two hooks it. Now how the hell do you use it?
Does it go above the rubber or below the rubber? Glass side or roof side. Where do I start? Which way do you move the tool? I didn't think such a simple tool could be such a pain in the ass. Thanks to whomever
answers Toby :(
goes between the rubber and the trimon the glass side. push it in until it hits the back of the trim, then drag it in a corner until you can feel the clip, you want to get it hooked on the clip then roll the tool back the other way to release the clip. it will drive you nuts, you'll swear a lot too. I like to use putty knives and other nondestructive tools as well to keel the trim up. you can also pull up on the trim and then use the tool to slowly pry as you go along to get the trim up. good luck, if you think that ones bad then wait till you try the rear going all the way around. ;)
1 - 2 of 2 Posts
