1 - 16 of 16 Posts
1980 Cadillac Fleetwood 90’d out
Torch out the piece. Pick it up with vice grips, heat it a little more. Then clamp it to fit the frame and hammer if needed. After its shaped I clean the peice with the grinder. Welding a bit then hammering is also a good method. I try to use the heat from cutting or welding to help shape the steel.
than i am doin it the easy way..lol :cool:
make a big c clamp with box tubing and a cylinder jack
voila
Originally posted by biggeazy-e@Aug 27 2005, 09:26 AM~3702501
:cheesy:
right next to the jackstand..
thats a little fancier then mine...but on the bright side mine cost a total of 0$ to build :biggrin:
Originally posted by One Luv@Aug 27 2005, 08:11 AM~3702447
i try not to use heat at all if possible, clamps and a hydro powered bended is what i use
heat is ok as long as you dont rapidly cool it
And as long as you dont use too much or too many times. I've been meaning to make one of those clamps for awhile now. I have all the stuff. Just too lazy to build tools.
Shaped a piece for the front in less than 5 min the other day. The proccess goes pretty quick from cutting to a little heating then fitting to the frame and shaping. Easier than what I used to do :biggrin:
Discussion Starter · #14 ·
on the belly?..... :confused:
Not the belly. The side from the the spring pocket to under the rocker. Has sort of an "S" shape in 1/4". Not one of the easier places. I'll take a quick pic of it tomarrow. Its just shaped. I haven't cleaned it or welded it yet
1 - 16 of 16 Posts
