1 - 14 of 14 Posts
Offering 24-Bit D/A converter, a high-powered MOSFET amplifier, Clarion's Optimedia display technology, a 4.2-inch full-color TFT display, and an attractive stainless steel faceplate, the DXZ855MP really does look as good as it sounds. Loaded with sound enhancement features, such as Clarion's ADF compressed-audio enhancer, and 2-band parametric EQ, the DXZ855MP is a unit that puts you in control of your sound. For easy system expansion, try a 4-volt/6-channel line level output. This is a source unit that truly does it all.
Key Features:
* Optimedia Display (Touch Panel Control)
* Full Color Full Dot TFT
* Plays MP3 and WMA Encoded CDs
* Plays CD-R/RW
* Anti-Distortion Filter
* 2-Band Parametric EQ
* Built-in adjustable Low Pass Crossover with Subwoofer Volume Control: 50Hz/80Hz/120Hz
* Magna Bass EX
* 24-Bit D/A Converter
* 212W (53W x 4)
* 4-Volt/6ch RCA Line Level Output
* Built-in Amplifier Bypass Circuit
* Stainless Faceplate
* Auto Dimmer
* Rotary Volume Control
* Screen Saver with User-Programmable Message Information
* Adjustable Display Brightness
* Motorized Detachable Control Panel
* CD Text, CD Titling, Station Titling
* IR Remote Control
* 18FM/6AM Presets
* Detachable Control Panel with Blinking LED for Anti-Theft
* CeNET Control of : DVD Changer, TV tuner, Sirius Satellite Radio Receiver and 6-Disc CD Changer
* iPod Control (Requires EA1251B / CeNET iPod Interface)
* 2ch AUX Input
Detailed Specifications:
Fully Evolved: Optimedia (3.2MB .zip)
TUNER SECTION
Frequency Bands
FM: (MHz) 0.2 MHz steps: 87.9 to 107.9
AM: (kHz) 10 kHz steps:530 to 1,710
FM Usable Sensitivity (dBf): 9
FM 50 dB Quieting Sensitivity (dBf): 15
FM Alternate Channel Selectivity (dBf): 70
FM Stereo Separation @1 kHz (dB): 32
FM Stereo Freq. Resp. @ 3 dB (Hz): 30 to 15,000
CD SECTION
Wow/Flutter (WRMS): Below measurable limit
S/N Ratio (dB):100
Frequency Response (Hz):5 to 20,000
Dynamic Range (dB): 96
Harmonic Distortion (%): 0.006
AUDIO SECTION
Power Output (DIN45324, +B = 14.4 V): 31W x 4
Maximum Power Output:53W x 4
GENERAL
Dimensions (W x H x D), mm: 178 x 50 x 160
Remote Control (W x H x D), mm: 43.4 X 112.7 X 12.5
Weight (kg): 1.7
Power Consumption: less than 15A
Speaker Impedance: 4 (4 to 8 allowable)
1 - 14 of 14 Posts
