1 - 12 of 12 Posts
ok I tried to raise the rear right of my car today after charging the batts, all I hear is a clicking sound....selonoids???? if so should I replace all of them on that side "4" also could this possibly be a faulty battery?.......do the selonoids automatically blow if the batts aren't charged?
definitely check your solenoids, is it jus the back that is clicking? does the front go up? if the front does go up you either have a bad battery or a bad motor, so you just switch it out for a new one.
HAVE SOMEONE FEEL THE NOIDS,WHILE U HIT THE SWITCH,sometimes it works 2 weed out the bad one
damn it, I think I know what my problem is now......I have a battery charger that only charges one battery at a time, what I did I put the charger on each battery seperatly thinking that it was charging the batts one by one, but I was just told that if I needed to charge the batts with a 12volt charger that I needed to unhook the batteries and charge them one by one????
ok I took all my batts out, recharged them one by one, now when I hit the switch to bring the rear of the car it, both side come up, but when I hit the switch to just bring up passenger side rear I hear a buzz like sound??????
1 - 12 of 12 Posts
