1 - 10 of 10 Posts
thanks you7 know anyone that paints around us well actually i have my painter i need someone to do designs and shit
I was going to suggest the clutch release bearing, but I think that is the throw out bearing in the USA :cheesy: !
Originally posted by scrapinnj@Nov 20 2003, 07:11 AM
are throw out bearings hard to replace
Not once you get to them, but you'll have to at least separate the engine and gearbox to get at the clutch and its operating mechanism.
Some cars are much easier than others, it depends on what car you have got. Front wheel drive cars are often quite easy to deal with because the gearbox is in the engine bay and not under the transmission tunnel.
If you have to take things to bits, have a good look at the condition of the clutch, because it might be worth replacing whilst everything is apart.
yeah if you are going through all that trouble for a throw out bearing, you might as well get the clutch and plate. Its better and cheaper if you get the whole kit to do this. That way you know you have a fresh clutch and you'll feel the difference.
NOPE.....I dunno chit about where to get stuff done in Jersey.
I'm sure that after the 2004 shows start I will meet alot of ppl and make some good contacts
1 - 10 of 10 Posts
