1 - 19 of 19 Posts
im trying too figure out a way too seat these 3 ton coils too the front there the pro hopper mach 3's,is there a certain way too seat them at the bottom on the lower control arm? anyone got pics? i got them cut down too like 4 1/2 or 5 turns the flat part of the coil is faceing up towards the upper on the deep cup
with the cut end of the spring on bottom and the cut turned towards the wheel it still dosn't seat properly...?
ok i drawn out a pic real quick too better explain and understand,lol ok im just trying too figure this out while i have my arms drops down,thought i ask if there's a certain way too seat them with the cut end were would it face on this pic,1,2,3 or 4?
Thanx for the help and fast responces ;)
;) right on thanx,back too putting them in just wanted too be sure before i actually did put them in
Originally posted by cdznutz42069@Sep 14 2005, 02:40 PM~3813690
You can see where it has a little dip in either position 1 or 3, set it there.
I'd say more around 3.... and the spring should sit nice.... ;)
True-S Mike
between 3 and 4 there should be a groove for the spring to rest in ( closer to the 3
i picked 3,cause 1 made it sit in angle looking like it was gonna pop,it's sitting nice now :biggrin: ,i must of been drunk when i cut my last coils there was only 3 turns on that mofo,lol nomore belly scrapeing,now it's time too mount my other knock off then im done ;)
took me maybe an hour in a half,sitting evenly now :biggrin: ,i got it raised all the way up too compress the coil maybe it will break it in a little bit
too bad you had them cut down...... phucks em up, 1 coil is litterally useless, or now almost double the rate it was....
on my G-body there are TWO holes in the lower and the end of the coil is supposed to sit past the first hole and level with the second hole, bit late now though. :)
Discussion Starter · #13 ·
how i screw them up?what u mean by double the rate? more stiffer?
~Individuals CC~
same problem, not the coil position....
I am so tired of fighting this kind of shit.... :(
my roadmaster is sitting sideways ,but the the coils are cut exactly even and they ar seated well,yet my car sits a 1" lower on the driver side,any suggestions?>
caved in belly or one spring pocket is pushed in more than the other :cool:
GOFUCKURSELF
I SAY SPRING POCKET............AND CHECK DONUTS..........
yeah i was thinking both things, crossmember or spring pockets,but its been like this from the day i cut the car but when i got it the front was sitting low and had those twist in spring spacers so i assumed the springs was shitty,i do need to reinforce things but its been slow going
mufasa what reinforcements you got i have none and was hopping like 35-40" only like 2 or 3 or 4 times :ugh:
1 - 19 of 19 Posts
