1 - 11 of 11 Posts
i know powerballs with coilover setup is better, but has anyone every made a standing3 with a coil under setup with chain and bridge? any pics :drama: :drama:
HOME BREWED, NO HELP
I have wondered the same for many years.....
i am running a coil under setup bridged and i just chained it yesterday i havent tried it yet cuz im waitin for the batteries but i hope it does do a 3wheel stand, your runnin coil under also right
GOFUCKURSELF
Its been done a lot!!
:wow: I KNOW you have the answers i seek, how can it be done???
Phoenix Chapter President
weight or chains
Much better with chains.
I had 2 cars coil under
1982 cutlass
1986 cutlass
I had the 82 had a problem with loosing the spring with a rooling 3
added chains and a clip that held them on to the axle, And a connection to the cylinder cup, Problem solved.
Then added the chains It really tied it all together. Standing 3 with coil under.
The only thing i liked about a coil under setup
You dont get the cylinder action in, firing into the trunk
what i didnt , driving down the road and the donut hitting the bridge.
ker chunk ker chunk.
A coil under could be a better setup set up right.
You can always build a perch behind the axle, and lowered down to the ground,
Then use a huge spring under the car and a coil under bridge, much further back in the trunk
The best coil under setup , would be a
1 a hydrohaulics cylinder
2 a hydrohaulics power ball over cylinder rod.
welded into the bridge.
THen chain the cylinder bottom cup, to the axle On 2 sides
Or use playground equipment like I did back in the day to tie to lock the spring solid to the cylinder to axle
1 - 11 of 11 Posts
