1 - 5 of 5 Posts
I painted a hood and after sanding it with 1000 then 2000 I color sanded using a wool pad
fallowing with a yellow foam pad. Now I am using system x one coumpound system. I have notice that some spots of the hood when looked at a side angle
I see a dull spot. When looked straight it looks fine. Now my question is sould I buff again with the wool then foam or just foam. Also what is the reason for this is it I am buffing it to dry, not enough speed on the buffer, not enough time one that spot. Any help or tips can help. Thanks guys.
Ttt
you may have burned through the clear, does it look like a circle? or does it just look dull?
when you wetsand next time do 1500/2000/2500 and if you got it do trizac it will make your buffing worlds easier
Looks dull
1 - 5 of 5 Posts
