1 - 20 of 22 Posts
· Premium Member
I dropped the pressure in the tank and the compressors didn't turn on. (set to 90 psi) I unhooked the power wire from the pressure switch and when i plugged it back in it just clicked. I waited a couple hours and plugged it up again and the turned on. Is this a warning that they are going out??
· Premium Member
Originally posted by 216RIDER@Nov 9 2003, 01:52 PM
doesnt sound like a good thing...
if you have a multimeter, you can check it out..
i'd have to dig it out...but what i don't understand, is why they started working again. :confused:
At first i thought it was the pressure switch, but when i took away the power and put it back on, they would just "click". Like they were locked up. They've been working ok since then though.
this makes me very sad in pants
no really i was looking at ur website and iw as like
damn that impalas nice (i dont really like impalas) but anyway
damn thats impalas nice it looks good on them wheels
then i got to the trunk and i started crying
i jus couldnt beleive someone would do that :(
· Premium Member
Originally posted by 216RIDER@Nov 9 2003, 02:50 PM
theyve...
how many pressure switches are you running?
just one. It kicks on around 90 or so, and cuts off at like 120. I got a basic 2 comp. 2 tank. 4 valve setup. all teed up for front and back.
· Face Puncher
it may have stuck for a moment..
are you running the power for the compressors through the switch, or using the switch to cycle a solenoid..
· Premium Member
let me draw up a diagram to better explain...
· Face Puncher
it looks like you have the full load of the compressors running through the pressure switch. most pressure switches cannot handle that kind of a load..
but then again, the solenoid should have another connection on it..
something like this..
there are some nice adjustable switches on eBay for like 60 bucks..
· Premium Member
Discussion Starter · #15 ·
so is it the switch, or the compressors??
And 216, i believe i have a seperate wire going to the solenoid, I just didn't draw it in. And i've had this setup for several years and i haven't had any problems with it except now. That's why i thought something was going out.
Originally posted by 1ofaknd@Jan 10 2004, 05:37 PM
it hasn't done it since, so i don't know if that was the problem. I'm getting some new compressors and steppin' up to 180 psi too :)
:0 your crazy man :uh:
j/k man ;)
hey man i don't think i have seen full pics of your truck i think i have seen the bags and suspention i don't remember can you post them up agian
1 - 20 of 22 Posts
