Originally posted by lowriderlife+Nov 14 2003, 02:21 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (lowriderlife @ Nov 14 2003, 02:21 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--Apache59@Nov 14 2003, 02:15 PM
Did you blow your motor racer boy???
You can put any motor you want in there. Now depending on the size you want is a different story. The same size motor will fit right where the other motor onced rested and should retain originallity, no problem. if you've ever seen the front end of a frame, especially where the motor mounts are, you'll notice a bunch of holes there. Those hole patterns are arranged specifically for either a small motor (V6) or a larger motor(V8). However, if you decided to "Go Big" with a big block, a custom mount would have to be fabricated.
just a little FYI stuff.
later man-
What type of convertible do you have?
