1 - 14 of 14 Posts
Could 4 switches for a 2 pump and 4 dump setup be wired like this:
1st switch- whole car up/left side down
2nd switch-front up/front down
3rd switch- back up/back down
4th switch-whole car up/right side down
wasnt sure if this could be done without having to run extra dumps or wires.
4th switch-whole car up/left side down
yes but why would you want two identical switches???
ok now that i corrected my first post can it be done the way listed in the first post?
just run the switches ...
front ..back , left sides , right sides and if you decide you just want rear corners disconect two wires and your set ...
and you'll have to get four six prongs .... instead of a typical two six prongs and two 3 prong (for corners)
the only thing i like about your wiring thou ...if some one gets in your car they are gonna be all kinds of f***'ed up
HAVE I ASKED IF YOUR COMING TO BLACK SUNDAY? IT WILL PROBABLY BE LIKE THE LAST GET TOGETHER OF THE SUMMER ?
YOU'LL USE ALL THE SAME DUMPS AND WIRES ... BUT YOU ALSO GOTTA REMEMBER IF YOU DROP A SIDE AND FILL IT BACK UP ... IT WORKS DOUBLE TIME . only has to move half the fluid
caps my bad
ttt
would it be possible to wire up the side switches to where they could only be dumped but not be able to raise?
yes. i have on min front back and dump left side dump right side den right rear and left rear 5 switches is all i need
you can wire them however you want. just spend time make quality jumps that wont fall apart and make sure you get them tight.Old switchboxes suck when the jumpers start falling off the terminals.
All you gotta remember is that ifyou have 2 pumps and four dumps, you have 6 different functions to work with and can put them in any combo. if you got 4 pumps and 4 dumpd, you got 8 functions to work with and so on.
I've wired my own switches before, and it can get hard to remember what you wanted to do, its so crowded in there when you dont have the right screwdriver.
1 - 14 of 14 Posts
