you'd use a water trap....Originally posted by mixedman@Sep 21 2005, 10:32 PM~3861279
empty the tank so the inside don't rust
The compressor turns on when the pressure in the tank goes below a pre-set point on your pressure switch.Originally posted by mixedman@Sep 25 2005, 07:34 AM~3880325
what do you do to get started. when you go out to your car, do you turn the compresser on, fill the tank, turn it off hit the switches. or do you keep the compresser on and constantly fill while you hit the switches. 0r does the compresser turn it self on?
