1 - 9 of 9 Posts
i have a 2000 mustang conv. that is cracked at the door would i put bondo on it and sand it do or do i use something else? :confused:
Without seeing it, I would first glue a peice of plastic behind it to brace it. Press the crack together gently, plastic melts with the glue, so after it dries real good, sand it down and see if you need a bit of bondo to seal it up.
K. Diaz
LAC RIDAH
Before I built my Caprice hopper my mom stepped on it breaking the back quarter window posts so I took a soldering iron witout the tip on, melted the post together from the back and used bondo to smooth out it all out front and back and now it looks like nothing happened, you wouldn't know if I didn't tell you, and It's as strong ans before the accident because of it all being the same plastice and all one piece. ;)
the car also has a bunch of skraches too, do i use bondo on them too?
I had the same thing happen to the passenger door of my '70 Roadrunner; but only instead of bondo I fixed it w/ krazy glue, and it came out perfect after light sanding. :thumbsup:
O.G. Member
:confused: This was about 3 years ago. What was the final outcome,
what did you end up doing and how did it turned out?
Give us update..
:guns:------------------------------------------------------:burn:
1 - 9 of 9 Posts
