imagine a whammy tank.
with a street pump on one end - with a small gear for ... 48 volts to work good
and the other end would be a high power hopping pump.
the whammy tank will share the same oil -
so only one set of dumps need to be wired in
but would have to figure out a way to route the preassurized lines to the front to have a t in them or something to be preasurized by either pump.
this could allow a street car to drive around and hit switches just rollin around with the street pump on 48v
and then when its time to hop you could use a diffrent switch wired to the hopping pump at 72+ volts
I dont know - maby its pointless
but I know when im driving around town / anywhere realley I cant seem to keep my fingers from flicking switches. no need to actually hop the car tho when driving just wana lay and play at a light and what not.
so having the double sided whammy setup for the front would / could allow the street car lay and play function , and still be able to hop like a champ when u wanted to.
im gona draw a pix and post it. yall can say yes or no to its feasability of working
