1 - 20 of 41 Posts
who has them? who makes them? how much? to fit 93 Fleetwood...the upper ones,that swivel or whatever.....
Originally posted by timdog57@Aug 3 2005, 08:11 PM
Hey Mo just drop your mounts.  ;)
[snapback]3537909[/snapback]​
lol...im puttin 14's on the back,and want to stand 3, without having to worry bout breaking the ears off my axle :/
[snapback]3537951[/snapback]​
how about if instead of ears you put legs? Arms and legs? hahaha :biggrin:
I thought you knew how to weld? Just make a cheap 100 buck pipe bender and do one yourself...
yeah,,im probly gonna make me some,,,,,which side should i make swivel with hyme joint or whatever? top or bottom?,,im thinking the top becuz of the eye bolt,....i found a way to do either side,,,,ill post pics when i make them
Prohoppers they work good, good for 3 wheeling to.
We put a pair of Prohopper upper and lowers in the Caddy we just built. This thing 3's on the spot no problem. All 4 twist with the flow of a 3, so you won't have a probelm with breaking anything. Also, you can tighten the jamb nut on them, the other side is also threaded so it will allow for movement.
Discussion Starter · #17 ·
guess imma have to get me some,,,other opinions feel free :biggrin: i was thinkin bout jus makin some,,but shit,,i might get these for real
Originally posted by allcoupedup@Aug 4 2005, 10:23 PM~3544404
We put a pair of Prohopper upper and lowers in the Caddy we just built.  This thing 3's on the spot no problem.  All 4 twist with the flow of a 3, so you won't have a probelm with breaking anything.  Also, you can tighten the jamb nut on then, the other side is also threaded so it will allow for movement.
uppers and lowers??? :0 whatcha think Moe?
Discussion Starter · #19 ·
i dunno,,,lowers are 175,,i think the biggest issue is the uppers,,i dunnno,,ill have to think bout that one
1 - 20 of 41 Posts
