1 - 20 of 28 Posts
you can - but i'd rather remove it. Did that with my cruiser. Works for me, I installed shorter cranks though. Maybe you should check for a shorter spring instead of cutting it.
Happy scrapin'!
Originally posted by havok@Jul 22 2003, 01:41 AM
Can I cut the spring on my fork to lower my bike?????
If you cut your spring, won't the little fork thing that its attached to (I think its the collar???) not fit anymore?
plus the link to springs
http://www.megalowrider.com/Item/F0055.htm
K. Diaz
only if ur not gonna ride it... i put one on my old trike and it rode like shit...waaay too low to the ground & the pedals scraped..
unless ur getting the adjustable one id say dont but it..
Discussion Starter #14
Taking the spring out or a down crown is to low for me to cruise I just want like 2 inches you have to be able to cut the spring you can on a car
u want a better way.. go to home depot or any hard were store and buy a screw with more part of screw and b4 it reaches the gooseneck you cut it at the back if its hitting it?
I took the spring out and still could ride my bike. Anyway - to slightly lift the bike when you took out the spring, I used two of these rubber-things that go in front of the crown instead of a spring. Worked fine - not as low as without the spring and still some kind of suspension. You just have to use a shorter skrew.
Discussion Starter #17
yo it took the spring out and it the shit should i pound the i think its the collar up to mount a shorter screw
Discussion Starter #19
What the fuck do you mean speak English, because i did'nt add an "s" on its, I am from America, IT'S called a typo.
1 - 20 of 28 Posts
