Yesteday my front right cylinder start leaking from bottom.
I thing its problem with oring. but dont know how to reprair it. Could somone write me how to change oring in cylinder and what kind and size of oring must buy?
Thanks
take old rings out go to were ever you get your rings from auto part store hardware etc. and have them match the size up-----as for how to,go to this site click tech page there is a step by step thing of them rebuilding a cylinder goodluck http://www.eternalrollerz.com/
cant tell which end you think is top or bottom!
if it leaks whre the rod goes in and out then it is the o-rings/seals
if it leaks where the hose goes it will be around the hose fitting OR it could be a weld weep
