1 - 9 of 9 Posts
Can you Guys give give me some tips?
Manufacturers?
Air Ride Technology?
York?
Use of Hydro Hoses?
Safety Issues?
Thanks?
I Dig Chix Wit Glasses!!!
Originally posted by JOE(CAPRICE)68@May 24 2011, 11:50 AM~20618402
Tell us what you would like from your setup??
:wave: :thumbsup:
talk to these guys at AAC on here the sponser , i got my kit from them and loved it i have it on my 64 impala vert for about 2 yrs no problems and worked out great and there prices were the best i had found out there when i was looking around my kit has the bolt in brakets and i used slam re7 all the way around 1/2 inch line only mods i had to do was drilling some holes no cutting at all no rubbing with the bags
Basically, I want to Lay and Play. No Hopping. Decent get up speed!
Buy from AAC, all good products.
3/8's line and valves would be fine for you
SMC - Valves
Parker Fittings
2 x 480's for a 5 gallon tank , . . .. or a YORK
Slam bags
Run shocks
Cut off switch under dash for compressors so you dont kill your battery
Run one water trap per compressor
Run a drain plug off the bottom of your tank
, . . . . . . i could keep going
L
[/b]
<!--QuoteBegin-lgh1157
@May 24 2011, 06:51 PM~20621434
SMC  - Valves
Parker Fittings
2 x 480's for a 5 gallon tank OR a YORK <----THIS
Slam bags<<--------Air Lift is good too
Run shocks
L
Originally posted by Simplicity@Jan 20 2011, 03:45 PM~19651513
ok, Im going to call it....."You gots to start somewhere kit"
$789 with Free shipping to the US states only. For my friends here at lay it low!
will include
4 x Dominator 2500 or 2600's your choice.
1 x 5 gallon Black 1/2" ported Tank
1 x Viair 280c Compressor
1/4" Watertrap
4 x SMC 3/8" Valves
1/8" Airline for gauges
3/8" Airline for bags
1 x Dual Needle Gauge (Black or White face)
110-145 PSI Pressure Switch
1 Relay with Harness
2 x Toggle or Rocker Swiches, your choice
Fitting Pack
I do recommend upgrading to a Viair 400c (xtra $50) well worth it.
This little kit is a Front Back Set up! Its complete and will come with everything except power wire, and a fuse holder, you will need brackets. We have most popular applications available. I also am willing to make any changes you require.
on this setup I would add two 480s and 4 more valves,and adjustable psi switch
Can some break down how the system and components work? Mounting? The best? Switches? Tanks size and number of Tanks?
Thanks in advance.
1 - 9 of 9 Posts
