Mach 3's with 2 turns cut off. 8" cylinders and a v6 in a cutlass. Will a regular cup and a donut do the trick or do I need deep cups and donuts?
with deep cups you have less of a chance of the cylinder popping out of the cup while you hop.Originally posted by GueroRegal@Jan 13 2009, 03:35 PM~12693489
x2Originally posted by 95lincoln@Jan 13 2009, 03:39 PM~12693530
deep cups are still better, but if you go with the normal cups you will be ok since you are not gonna hop.Originally posted by GueroRegal@Jan 13 2009, 03:50 PM~12693651
Not planning on hopping its just a lay and play.
x3Originally posted by CAPRICE2LOW@Jan 13 2009, 06:45 PM~12693597
X2 i will ONLY use deep cups
:thumbsup: real talkOriginally posted by AndrewH@Jan 13 2009, 07:21 PM~12693983
regular cups are a waste of coil only good for when your springs wear out and the cars lower than you'd like
