1 - 2 of 2 Posts
My brothers truck has two pumps, four dumps 4 batts at 48 volts, the front would raise but would not dump. I checked all the wiring and it was fine so I decided to take the coil off the dump. It smelt like it was burnt, both of them. Is it possible that they both are burnt up and what would have caused that?
if a switch sticks open or or something that causes the dump to get a constant current flow it will eventualy get really hot and melt inside and not work anymore, i had this happen a couple of times form bad switches. take the 2 wires and connect one to the positive post on a bettery and the other wire to the negative post of a batery if you dont here a click there either burnt out, or you could have sweld the dumps..
1 - 2 of 2 Posts
